Thermalright HR-03-GT Graphics Cooler (8800 GT & HD3800 Compatible)
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
The cooler many have been waiting for is now available and in stock at OcUK:-
Thermalright HR-03-GT VGA Cooler
The HR-03 series started life early 2007 and is highly recommended by many computer hardware enthusiasts. It doesn’t matter if it’s the HR-03 PLUS or the HR-03/R600, they are all able to bring out the best in your high end video card with unprecedented overclocking results by providing maximum cooling performance. The new HR-03 GT uses six heatpipes and a double sided heatsink base that can be used with any 92mm fan. So if you are not prepared for the onslaught of heat and noise stock coolers generate, get the new HR-03 GT!
Compatible with:
- 6800 Series
- 7800 Series
- 7900 Series
- 7950 GT
- 8600 GTS
- 8800 GT
- X1800 Series
- X1900 Series
- HD3850 Series
- HD3870 Series
- Supports 92mm Fans
- Weight: 410g
Price: £29.99+VAT (£35.24 inc VAT)
BUY NOW!!
Looks good am tempted but still not sure about ramsinks keep hearing of peoples sinks falling off on after market coolers with the gt.
Hope someone buys one and gives us their opinion.
I've not had any problems with my ramsinks. Trying to get a heatsink on the small power regulation components is another matter. I can't get anything to stick without resorting to some epoxy based material. I assume it's down to lack of surface area but I don't want to epoxy these in case the card fails and I need to put the stock cooler back on for RMA. ;)
I put an Accelero 1 and a Sharkoon 120mm fan on my reference Leadtek. It's currently running at 700/1750/2000 and never gets above 45c at full load.
These coolers look a bit "thicker" than the Accelero which already takes up an extra slot or two once you slap a fan on it. This could be an issue for some people.
I got one on my 8800GTS 320(from OCUK) and its great cant fault it at all.
Heat sinks have never came off and work great.
this is more than double the price of an accelero s1 Gibbo, and the accelero is much better, you can strap either a 140mm fan to it or two 120mm fans, making it extremely cool and no other aftermarket cooler can even compete with that, is there any reason to get this over an accelero s1 apart from the fact you have no stock of the accelero?
Just buy a Zalman VF900 instead for your GT. :D
Then maybe consider the above.
or if OC could get some thermaltake duo orbs in stock and some acceleros it would be nice, we need decent coolers at cheap prices, anything over £20 for a gpu cooler aint worth it when you can get an accelero for so cheap, i wouldnt buy the hr-03 even if you offered free delievery
HI there
Accelero's are actually here, just not booked in yet, but should be booked into stock later today or early tomorrow.
