sorry I have a MX310 actually, not a mx318...and yes it's 800dpi
hmm no I don't experience that. Sounds like something is causing your mouse to lag. Vsync perhaps?
Its wireless could that be it? I mean even on the desktop if I move it really fast to the side the cursor just stops moving.
Played UT3 a bit today and so far I like it, but I'm really not used to the double key dodge, cuz of the way I tap strafe keys it often pushes me over the edge with unintended dodge. There is no option to turn it off as well.
[DW]Muffin;10603024 said:You don't need a mouse that moves million miles per cm just enough to do a 360 pretty easily, depends on your preference. Proper mouse and mat makes it easier to aim the mouse to a specific point though.
I've been playing it a few hours and its quite hard for me, some people just move so quick and dodge behind you its something I cant do I dont get how they do it so quick and sometimes they just skipping round you like one minute you see em one minute you dont, I think I may need a new mouse :\.
So I could modifiy the settings in the ini files so that when I press the left key and right key I can move right to left extra quick?
Any idea what things to edit for that?
I was playing you on a dm server on friday and I did notice you didn't seem to move around as much as most people. I killed you a few times and mostly I could tell it was you before I killed you because of the way you were moving (or maybe I just recognised your character after the frist couple of times, probably both). The key thing is keep holding down at least one direction unless you think you're safe / really need to take a shot that needs you to be still.
The mouse issues don't sound very useful though, I used to have all sorts of issues with an optical mouse directly on the desk. Some mice are pretty tetchy about it. I'm currently using a hardback book though and it's allright (but a bit high :s)
Off hand i can't remember what they are from the old versions of the game but can have a hunt around to see whats about. Hopefully find something that tells me where this might be located now.
SCM
I take first sometimes but seem to have a million deathsI have noticed that a lot of people just camp the armor as well...maybe that's the reason.
Oh yes, dont let me forget to say
"Pickup the soap bitches!"
