tables in access
10 Jan 2006
i currently have 3 tables all the same apart from one is bookid, the other is journalid, and technicalreportid. all 3 tables have fields, name,author,year published. how can i link these tables to use effeciently in access. basicdally i am creating a database where peopel take out books
23 Dec 2002
Bristol
this should be in HTML, Graphics & Programming.
try normalising you DB, if all the tables are the same then then should all be 1 table.
8 Feb 2004
London
Sounds like a homework assignment.
Anyway, what I would do is create two new tables to replace the existing 3 tables.
New table 1: ItemTypesTable
Fields: ID, Description
Example data:
1, 'Book'
2, 'Journal'
3, 'Technical Report'
New table 2: ItemsTable
Fields: ID, ItemTypeID, name, author, year published
Example data:
1, 3, 'Tech Report 1', 'J Bloggs', 2001
ItemTypeID would be linked to your ItemTypesTable.
