Phew..... I nearly poo'd myself.....
22 Oct 2006
Just went to reflash my 8800gt with the modded vcore BIOS,
All went okay and successfull. then reboot and nothing!!!!!!
Run downstairs rip apart rents PC to get a PCI GFX card. have to reflash back to stock.
But i was pooping myself for about 10mins....
I'll have another go tomorrow night :D
Now here's a lesson for all you you potential bios flasher's, wear a nappie before you go in for the flash :p
Good luck with the flash.;)
What have you done to make the flash fail?? :eek:
Is it ok to have a second PCI-E card on a sli mobo to flash the primary card back or does it have to be a cheapo PCI card?
If your Force Flashing it could try Flash the spare lol.
I use a old PCI GPU or Blind Flash, infact I dont as its made into a Autobat file all I need do Blind is press "Y".
i'm not sure wjhy it failed, it was the modded bios from XS.
I think it was more luck that the rents computer is pants ;) First of all, all i could find was a agp card thats about 5 years old...
I might just write my own modded bios using the stock bios tonight and try that.
I think its the same bios I used, went fine for me, you using latest version of NVFlash?
When i flash, I normally run the flash several times to try and make sure it's done (bit like pressing C or CE on a calculator multiple times because I could never remember which one clears everything lol).
But lesson number #1: Always make up a disk FIRST to flash blindly back to your original bios. (and if your clever enough a usb stick to boot from (which can be a pain in the rear end).
Matthew
I don't think you can wreck a graphics card through bios flashing.
If it fails you just drop in a PCI card and flash again or create an automated boot disk.
Think again mate, I have a very dead 6800GT that I killed by flashing incorrectly, no matter how many re-flashed I carried out, it never worked again.
Its still around here somewhere in a jiffy bag! :o
It is possible, pretty unlikely though. So long as you have a blind flash disk to hand and set your mobo to boot from CD > HDD first you should be able to rescue it.
Cant you try get an RMA on it lol?
I wonder.... Actually it was around £305 inc VAT when I bought it, so that must make it about 3 years old at least (Leadtek Winfast A400 GT TDH) GX-068-LT is the Oc/Uk stock sticker on the box , which I still have!
I think its a tad out of warranty..... :o
