- 2 Dec 2007
A couple of nights ago I moved everything over into my new case and ever since, my two identical Maxtor 300Gb SATA drives haven't been detected in the BIOS. My 40Gb PATA is fine, as is everything else.
I've made sure the cables are seated correctly, swapped out different data cables, tried different power connectors from the PSU but no joy.
Am a bit gutted as one was the backup of the other..
How likely is it that:
a) the SATA controller is broken?
b) BOTH drives have died?
c) the PSU is no longer supplying power to the SATA drives...but somehow is supplying it to the PATA HDD/DVD/Motherboard?
I think I'm going to get a new SATA drive if I can't figure it out tonight. If that works, then the drives are kaput and I needed to replace them anyway, if it doesn't I can be fairly sure it's the motherboard/something else and I've got even more storage...but I don't think it'll be a Maxtor...
Both drives detected in BIOS and the OS!
