- 5 Dec 2004
- Horsham, UK
Microsoft have just issues a hotfix for slow performance with linked display adapters.
andSYMPTOMS
In some scenarios, games and benchmarks perform more poorly than expected on a Windows Vista-based computer. This issue occurs when the games and the benchmarks use multiple display adapters in a Linked Display Adapter (LDA) configuration.
Info courtesy of The Inquirer, but their link to the MS site is borked.SYMPTOMS
Consider the following scenario:
• You have a Windows Vista-based computer.
• The computer uses two or more DirectX-compatible graphics processing units (GPUs) in a linked configuration.
• You are using a DirectX 10 application and driver.
In this scenario, the computer's graphics performance indicates that only a single GPU is being used.
