ok - so after testing all my XVIDs/DIVX's on my Dell 2407 - 1080p via VGA - I decided to buy a 2nd XBOX 360 (Falcon one ) as a media centre connected to my Plasma
so boot it up set to 720p (Plasma is not 1080p) and all my hi-def DIVX trailers etc work, but any SD DIVX files = NO - just black screen - after a lot of testing I've found the following
in VGA
@ 1080p = all DIVX/XVID files play fine
less than 1080p but greater than 640p = 50:50 work, most SD ones don't work - all ones that don't work = black screen - with sound
640p = all work BUT SD DIVX are output incorrect aspect ratio ... 1:2.35 looks more like 1:3 ... and 1:1.85 is not full widescreen .. so bascially everything is squashed
via HDMI
all fine ... all aspect ratios correct, no matter the res, the files play ....
so whats wrong with VGA ?
and when are you going to fix the bug Microsoft ?
Mark.
in VGA
via HDMI
Mark.
