Long Weekend Special - Amazing Prices, GET IN, GET YOUR WALLETS OUT!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some cracking deals for you:-
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM
The 8800 series is the world's first DirectX 10 graphics card with full Shader Model 4.0 support. It delivers unparalleled levels of graphics realism and film-quality effects. Even more, it also supports the NVIDIA Lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. Built for Windows Vista™, the 8800 series ensures the best possible performance when running the Windows Vista 3D graphical user interface. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported. The WinFast® PX8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported.
- GeForce 8800 GTX core running at 575MHz
- Shader Clock Speed of 1350MHz
- 768MB GDDR3 Memory running at 1800MHz
- 384-Bit Memory Interface
- 128 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 36.8 billion/sec
- Memory Bandwidth: 86.4GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 1yr Warranty!
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
Previously sold for £237.99+VAT (£279.64 Inc. VAT)
Price: £224.99+VAT (£264.36 inc VAT)
BUY NOW!!
Point of View GeForce 8800 GTX "MotoGP & Settlers Edition" 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
- Shader Model 4.0
- HDCP Enabled!!
- Supplied with MotoGP'07 PC Game & Settlers 6:Rise of an Empire PC Game
- 3yr Warranty!
Previously sold for £247.99+VAT (£291.39 Inc. VAT)
Price: £237.99+VAT (£279.64 Inc. VAT)
BUY NOW!!
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail
With four cores and high scores, the Intel® Core™2 Professional processor Q6600 is flat out the most extreme desktop processor. It’s specifically built for hardcore enthusiasts who don’t take kindly to compromise. Based on the Core™ Microarchitecture, the Intel® Core™2 Professional Q6600 is a multitasking monster, and the ultimate multimedia engine. The performance? It eats benchmarks for breakfast. This energy efficient version consumes 10W less power than the traditional Q6600 which means it produces less heat and is better suited for overclocking purposes.
- Quad Core Technology
- SLACR Stepping, 95W
- Energy Efficient Edition (Consumes 10W less power, less heat, better overclocking)
- 2.40GHz clock speed
- 8MB L2 Cache
- Intel Speedstep Technology
- EM64T 64-Bit Technology
- Execute Disable Bit
- Cooler running technology, less heat and less noise!
- Supplied with Intel referance heatsink & fan
Previously sold for £141.99+VAT (£166.84 Inc. VAT)
Price: £133.99+VAT (£157.44 inc VAT)
BUY NOW!!
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK)
As part of OCZ’s Gold series, the PC2-6400 2GB modules deliver the performance and speed gamers require for today’s graphic-intensive DirectX 10 PC games. At 800MHz, the 2GB Gold Edition runs at 5-5-5 latency timings and offers unprecedented stability on the latest AMD and Intel platforms. As a Vista up-grader, the PC2-6400 4GB dual channel kit will provide excellent memory bandwidth and deliver the best possible gaming and productivity on Vista systems.
All Gold Edition modules are 100% hand-tested for quality assurance and compatibility and feature high quality, gold-mirrored XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ Gold series module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
* XTC (Xtreme Thermal Convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. In this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. At the same time, mechanical stability is maintained.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.1V ± 5% without invalidating their OCZ Lifetime Warranty.
- 800MHz DDR2
- CL 5-5-5-18
- Unbuffered
- Gold XTC* Heatspreader
- OCZ Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
Previously sold for £79.99+VAT (£93.99 Inc. VAT)
Price: £69.99+VAT (£82.24 Inc. VAT)
BUY NOW!!
Seagate Barracuda 7200.11 500GB SATA-II 32MB Cache - OEM (ST3500320AS)
By combining proven components and state-of-the-art technology, the Seagate Barracuda 7200.11 family delivers up to 1TB of storage. Designed with Seagate’s 2nd generation perpendicular recording, the capacity, reliability and performance of this drive ensure the longevity of digital content for years to come.
- Capacity: 500GB
- Cache: 32MB
- Interface: SATA-II
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 5 Years
Previously sold for £61.99+VAT (£72.84 Inc. VAT)
Price: £59.99+VAT (£70.49 Inc. VAT)
BUY NOW!!
Samsung SM-245B 24" Widescreen LCD Monitor - Black
Imagine having elbow room on screen. That’s exactly what you get with the Samsung 245B series of widescreen LCD monitors. Wide 16:10 aspect ratios let you multitask, with room for more than one application at a time. The extra room also makes working with graphics programs and multiple tool palletes easier. An ultra-fast 5 ms (G to G) response time is perfect for motion graphics editing. And exclusive MagicBright 3,™ MagicColor™ and MagicTune™ technologies give you complete control over outstanding color. All the color. All the room. With the Samsung 245B, it’s not hard to imagine.
- Viewable Area: 24” Widescreen (1920x1200 Resolution)
- Interface: Analog / Digital
- Response Time: 5ms
- 16.7M Colours
- Contrast Ratio: 3000:1
- Viewing Angle (H/V): 160°/ 160°
- Brightness: 400cd/m2
- Height Adjustable stand with tilt & swivel
- 3 Years On-Site Warranty with Samsung
Previously sold for £259.99+VAT (£305.49 Inc. VAT)
Price: £249.99+VAT (£293.74 Inc. VAT)
BUY NOW!!
Hitachi L42VP01U 42" Full HD 1080p Freeview LCD TV
Full HD L42VP01U offers 2.6 times more pixels compared to a standard XGA panel. This new end LCD model features the latest technology to display superb image quality. All this combined with its great design, makes this TV the perfect addition to your home.
- FULL HD ready (480i, 480p, 576i, 576p, 720p, 1080i and 1080p supported) (Sky HD Approved + Xbox HD Ready)
- 42" Screen Size
- 1920 x 1080 Resolution
- Contrast ratio: 1500:1
- Viewing angle: 178/178
- Sound output: 8W x 2
- A2/NiCAM Stereo
- Smartext with EPG
- Auto setup
- Headphone x 1 (side)
- HDMI x 2
- Component x 1
- Scart x 2
- PC input, D-sub x 1
- Dimensions (WxHxD) 1036x750x270 mm
Price: £649.99+VAT (£763.74 inc VAT)
BUY NOW!!
"Ultima OC Complete 8800GT" Intel Core 2 Quad Q6600 2.40GHz @ QX6950+ 3.20GHz+ Quad Core SILENT DDR2 Complete System
If you are looking for the ultimate INTEL box then look no further than the Ultima OC 8800 GT 512MB Intel Core 2 Quad Q6600 Quad Core overclocked beyond yet to be released QX6950 clock speeds. Supplied as a complete kit this system has the performance to rival ones costing nearly twice the price due to OcUK's expert engineers pre-overclocking this system to safe and reliable settings for a huge performance boost. This system packs enough power to play the latest games at maximum details including AA/AF upto resolutions of 2560x1600 without breaking a sweat including latest DX10 titles such as Bioshock, Crysis and Unreal games. This system comes complete with Saitek Eclipse 2 Gaming Keyboard, Razer Krait Gaming mouse, Logitech 2.1 Speaker System and Samsung 22" 2ms DVI LCD Monitor. Supplied pre-built it has an impressive specification to say the least :-
- Intel Core 2 Quad Q6600 GO 2.40GHz Quad Core CPU Overclocked too a minimum of 3.20GHz and beyond.
- Arctic Cooling Freezer 7 Pro Intel approved cooler
- Abit IP35 Intel P35 (Socket LGA775) PCI-Express DDR2 Motherboard
- Award winning Corsair 2GB PC2-6400 CAS4 (2x1GB) Dual Channel Kit (Overclocked at 850MHz+) (Note when upgrading to 4GB overclock drops to 3.00GHz on CPU)
- 500GB Samsung 16MB Cache SATA-2 Hard Drive
- NVIDIA 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express) DirectX 10 Graphics Card
- Pioneer 112DBK 20x DVD±RW Dual Layer ReWriter (Black)
- Antec NINE HUNDRED Gamers ATX Case
- OCZ 600W Next Generation Power Supply
- Logitech S220 2.1 Speaker System - Black
- Samsung SM-226BW 22" Widescreen LCD Monitor - Black
- Saitek Eclipse 2 Illuminated Gaming Keyboard - Blue/Red/Purple
- Razer Krait 1600dpi Professional Gaming Mouse
- Supplied with Ghost Recon 2 and Call of Juarez PC Games
Note - All Ultima systems are built and installed on demand, during busy periods this may cause a delay of between 24 and 48 hours in despatching your order. The Ultima can be supplied assembled with or without your choice of installed operating system but is supplied without keyboard, mouse, speakers or monitor (all of which are available elsewhere in this on-line store).
Note - If you select the 4GB Memory Upgrade option then the CPU overclock is reduced to 3.0GHz region to maintain stability with all four memory banks filled.
*** Previously sold for : £999.00+VAT (£1173.83 Inc. VAT) ***
Price: £879.00+VAT (£1,032.83 inc VAT)
BUY NOW!!
These are incredible deals and we should be if not the cheapest in the UK extremely competitive. :)
