Just got this game yesterday, fantastic game. Loving the singleplayer at the minute. Multiplayer is enjoyable, however it does need much much bigger maps.
Someone who agrees with me!
The maps suck, fact.
You can spawn kill on almost every map, there is little chance to push forward before your already dead.
Small maps encourage camping
Medal of honour spearhead and cod:uo got it just right
Future dev teams should really consider making a proper FPS.
Am i right in saying that if you install the 1.3 patch you won't be able to play on servers that haven't patched to 1.3 yet?This patch addresses the issue reported by community member Uzi Kidding which now catches some files bypassing the pure client test. In addition this update will set properties so that Anti-lag is always enabled upon map loads, an optimization for Sniper Rifle accuracty at certain distances, as well a fix so text chat between rounds of multiplayer will no longer cut out at the end. The 1.3 patch will also include all previous fixes from previous patches.
Same AND says my key is in use
Can connect fine, although servers take longer than 10, been upto 20 in some cases before connecting
Not possible, goes up to 11 and gives up - The cvars are locked to change that cmd too.
Unless you mean /reconnect @ 10![]()
I just recently got this game, but although I subscribed to this thread shortly after it was made I haven't exactly been following it thoroughly. Are there any important things I should know? Such as common problems and how to resolve them.
Open the console and set
cl_connection attempts 30
THats what i do works every time then.
Or you can go into your config_mp.cfg file and add
seta cl_connectionAttempts "30"
Then you don't have to worry about it resetting back to 10 each time you play.
