Update to Weekend Special - OcUK 8800 GTX 768MB Only £204.99+VAT (£240.86 Inc. VAT)!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK we've managed to pull of a mental 8800 GTX deal!
This new prices makes the GTX as cheap as some of the overclocked 8800 GT's and as cheap as the forth coming 8800 GTS possibly if priced rumours are true, so for those who crave only the best OcUK brings you the 8800 GTX at an unbelievable low price!!
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM
The 8800 series is the world's first DirectX 10 graphics card with full Shader Model 4.0 support. It delivers unparalleled levels of graphics realism and film-quality effects. Even more, it also supports the NVIDIA Lumenex™ engine to give unsurpassed image quality, floating point accuracy, and fast frame rates. Built for Windows Vista™, the 8800 series ensures the best possible performance when running the Windows Vista 3D graphical user interface. The 8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported. The WinFast® PX8800 series complies with many cutting-edge Xtreme-HD features. It provides two Dual-Link DVI connections to support two hi-end, ultra-large, 30-inch LCD monitors at a mind bending 2560x1600 resolution. With an embedded revolutionary HDTV encoder, the 8800 series also supports crystal clear HDTV output up to 1080i. On top of this, it enhances compatibility with other video standards, delivers hitherto undreamt of clarity, smooth video, accurate color, and precise image scaling for all video content such as MPEG-2, WMV, WMV HD with NVIDIA exclusive PureVideo™ HD technology. What's more, playback of HD DVD, Blu-ray Disc, and other protected content at full HD resolutions with integrated High-bandwidth Digital Content Protection (HDCP) is fully supported.
- GeForce 8800 GTX core running at 575MHz
- Shader Clock Speed of 1350MHz
- 768MB GDDR3 Memory running at 1800MHz
- 384-Bit Memory Interface
- 128 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 36.8 billion/sec
- Memory Bandwidth: 86.4GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready – Upto 2x the performance of a single GPU (Available on with future driver release)
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 1yr Warranty!
Note: This card is 275mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended.
***Previously sold for £237.99+VAT***
Price: £204.99+VAT (£240.86 Inc. VAT) Saving you £33.00+VAT (£38.78 Inc. VAT)
BUY NOW!!
Thats right folks an 8800 GTX shipped and landed at your door for sub £250 all in!!! :D :)
Happy XMAS!
Gibbo
Hi there
Fixed it! :)
Stunning deal guys, a GTX thats very close to GT prices but still offers the performance of the superior GTX. :)
Think I would pass on having a computer that crap!:o
If you use a computer for everything BUT games, then £240 can get you a computer more than powerful enough to run most applications. My computer I work on at the moment is worth about £200 at the moment, it runs 3DS Max, Photoshop, Premiere, Poser, Office 2007 applications, just about anything I throw at it really.
Good deal though, shame i haven't got spare cash.
[TW]Fox;10643130 said:
How do they compare performance wise to the new GTS?
Pretty much shoulder to shoulder. In some games GTS wins out for having higher clocked core and SP, in some GTX has an edge with higher mem bandwidth and more ROPs.
But the GTS consumes less power and has far better OC potential.
