- 3 Sep 2003
Looking for some critique on my Loch Venachar pano which I'm hoping to get printed for an xmas gift:
This is a quarter sized low compressed jpg, hence the pixely text. Looking on feedback whether the generally text and layout is OK. (can't do much about the overcast sky in the panorama)
I have a few cheap frames which can fit a 18" by 8.5" , and I can get a print size of 20" by 8" using photobox so I'm hoping this image should be ok size wise.
(Unless I'd be best designing the image around the 20" by 8", then trimming it down to fit?)
Alternatively should I look elsewhere for getting a custom print size to fit the frame (actually 46 by 21.5cm)
Pretty please.
