So, Ive been building/upgrading PCs for the last 9 years or so. I've developed my tastes so that I prefer a silent PC over a noisy one - delta fans saw to this. I was an early adopter of water cooling - long before water cooling parts were freely available. As an example I had to use tupperware containers for reservoirs and heatercores (from cars) as rads. The heatercores have shrouds on them made from cardboard, to which the fans are attached. The fans are controlled using rheostats. Its all very ghetto.
Anway, Ive been continuously upgrading over the last few years and always test out the cpu using the stock air cooler. Once everything is running fine, I replace the heatsink and fan units with the waterblocks and everything goes quiet.
Ive always found air coolers to be very noisy and nothing has changed my opinion of this...until now.
I built myself a new PC for my bedroom. It was designed to be able to play HD video, music and surf the net. To this end I needed a fast CPU, and basic GPU and everything to be as quiet as possible. I was not prepared to spend extra on watercooling, so I gambled on air cooling.
System spec:
Intel E2160
2GB ram
Gigabyte P31 DS3 motherboard (fanless)
Corsair VX450W (very quiet, almost silent)
Thermalright Ultra-120A CPU Cooler
Noctua 1200rpm fan
ATI HD2600PRO (fanless)
Samsung 501LJ 500GB
I put together this system and when I turned it on, I thought it wasnt actually working. The damn power light on the case was broken. It was so quiet. It was only when I plugged it into a monitor and everything was coming up on the screen that I realised that it was working.
I just wanted to say that no longer is a silent PC exclusive to those that run watercooled. Air cooled systems can be just a quiet. My water pump, 4 HDs, PSU fan and 4*120mm fans on my water cooled system actually make more noise than the new PC. (OK fair enough, my water cooled PC is more powerful in every department, but its impressive that an air cooled PC can run virtually silent).
System spec:
Intel E2160
2GB ram
Noctua 1200rpm fan
Samsung 501LJ 500GB
with all the doors closed. I had first hand experience of this. This is when I had to go out of my way and salvage my own watercooling setup. I spent days at plumbers' merchants looking for suitable parts. OCUK, like most other retailers, didnt want anything to do with watercooling as it was still experimental and the retailers did not want to be held responsible for people frying their hardware by spilling water all over it.
