Just look the 8800GT's, mine reaches 88C under load (with revised larger fan).
i dont understand why you wouldnt freak out when it goes above 75 at any point in the month and jump around like a maniac looking for a fire extinguisher. i freak out when it hits 60
I'm sure the dual slot cooler's arent as efficient as people say, in regards to pushing hot air out of the case.
I'm after a single-slot to fit in my shuttle![]()
Having had a few dual-slot coolers I must say they do chuck out an immense amount of hot air from the exaust when the card is running under full load, pity you can't do that with a single slot design because there would be no space to plug in the graphics cardI'm sure the dual slot cooler's arent as efficient as people say, in regards to pushing hot air out of the case
Have a look for the Powercolor PCS version which is single slot with what looks like a zalman cooler on it. I've got the dual slot version and its v quiet
EDIT its on ocuk as extreme silent version or something like that
or prevent a shuttle owner from putting the case cover back on?It may have a single slot backplate but i'm pretty sure that cooler will block the slot under the card.
Oh really? I've not seen a Shuttle recently? have some of them got space for dual slot graphics card now?depends what shuttle you mean
no worries, but it got me thinking, could a Themalright heatsink fit info a shuttle if you had no PCI cards?
I mean that Thermalright heatsink can be attached in two different ways right? I'm thinking off having the bulk of the heatsink 'flipped' onto the back of the card?
also what Shuttle you running out of sheer curiosity
I'm running an SG31G2. I suppose a 3850 is a viable solution, but would prefer a 3870. Either that or get another 8800GT after RMAing my Zotac.
