100 indicated is around 85 gps for me
Am I right in thinking that on large slopes GPS gets a bit funny and doesnt display your real speed?
Garmin's specifications quote 0.1mph accuracy but due to signal degredation problems noted above, perhaps 0.5mph accuracy in average automobile applications would be what you can count on.
Usually they're accurate to around 0.1mph - but this does vary upon conditions and manufacturer's spec. Some are more accurate (0.01mph for example).
According to one (seemingly outdated?) website:
Ahhh right so its better to go with what the TomTom speed indicator then the speedo?
So better to just use the speedo then?
Off topic,Gaijin I still haven't spotted your Civic driving around Brighton yet!
i personally take note of how "out" my speedo is
if my speed says 30 im doing 28. You only get a ticket from a fixed speed camera at 10 % + 1 which is 34. So if my speed says 32 or whatever i know im actual fact only doing a real 30 and nowhere near the 35mph needed for a ticket so dont bother
so check your actual speedo, but just learn how "out" it is.
