When using barbell bars etc, how do you say what weight you are lifting?
When using DB you say the weight of one DB ie. if you curl 10kg DBs then you say I curl 10kgs
When using a bar you add up the total weight so add the weight of the plates and the bar ie. 2x10kg plus bar = 30kgs
