Abit IP35 Pro or Abit IP35?
Just had a quick look at the abit site,
The advantages of the pro seem to be:
Addition of U-guru which i belive is some kind of overclocking tool
Official support for DDR2 1066, as opposed to DDR2 800
addition of cmos reset swith on back panel
2x esata ports
So I guess it will overclock a little better, depends wether you think the big jump in price is worth it, I gues you would need to look at better RAM to take advantage.
im sure the pro also uses solid state high quality caps all over the board, whereas the lower models only use the high quality capacitors at key areas and use lower quality older tech ones elsewhere?
Im sure I;ve seen that somewhere
Oh yeh, hard one to spot, that!
on the site it says of the PRO..."Solid state capacitors."
and of the regular " solid state capacitors around the cpu socket"
Which suggests the non-pro does have lower quaity caps elswere.
what real world impact will that cause, ie increase instability? or whatever
