Amazing Memory Deals on OcUK's This Week Only!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
As its Christmas I have some truly stunning deals for you guys on memory:-
Corsair 2GB DDR2 XMS2-6400C4 TwinX (2x1GB)
The Twin2X2048-6400C4 is a 2048 MByte matched pair of DDR2 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 800MHz at the low latencies of 4-4-4-12. The Twin2X2048-6400C4 comes with Enhanced Performance Profiles (EPP), the open standard for performance module SPD’s jointly developed by Corsair and NVIDIA. EPP SPD’s on Corsair modules allow users to automatically configure EPP enabled motherboards with aggressive memory performance settings, for maximum memory and system performance.
Price: £30.99+VAT (£36.41 inc VAT)
BUY NOW!!
Corsair 4GB DDR2 XMS2 PC2-6400C5 TwinX (2x2GB)
The Twin2X4096-6400C5 G is a 4096MByte matched pair of DDR2 SDRAM DIMMs. This part delivers outstanding performance in the latest generation of dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 800MHz at the low latencies of 5-5-5-18. Corsair’s line of 4GB memory kits are designed for PCs featuring 64-bit operating systems. Please note: Installing 4GB onto PCs with 32-bit operating systems is not advised since 32-bit operating systems do not support 4GB of system memory.
Price: £64.99+VAT (£76.36 inc VAT)
BUY NOW!!
Corsair 2GB DDR2 XMS2 Dominator PC2-8500C5 TwinX (2x1GB)
The Dominator Series Twin2X2048-8500C5D is a 2048 MByte matched pair of DDR2 SDRAM DIMMs built using Corsair’s latest high performance heat sink with Dual-Path Heat Xchange (DHX) technology. This part delivers outstanding performance in the latest generation of dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed. This memory has been verified to operate at 1066MHz at latencies of 5-5-5-15. The Twin2X2048-8500C5D comes with
Enhanced Performance Profiles (EPP), the open standard for performance module SPD’s jointly developed by Corsair and NVIDIA. EPP SPD’s on Corsair modules allow users to automatically configure EPP enabled motherboards with aggressive memory performance settings, for maximum memory and system performance. Performance of these modules incorporating DHX can be further enhanced by using the optional Dominator Airflow Fan, for even more cooling and protection.
Price: £67.99+VAT (£79.89 inc VAT)
BUY NOW!!
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK)
As part of OCZ’s Gold series, the PC2-6400 2GB modules deliver the performance and speed gamers require for today’s graphic-intensive DirectX 10 PC games. At 800MHz, the 2GB Gold Edition runs at 5-5-5 latency timings and offers unprecedented stability on the latest AMD and Intel platforms. As a Vista up-grader, the PC2-6400 4GB dual channel kit will provide excellent memory bandwidth and deliver the best possible gaming and productivity on Vista systems.
All Gold Edition modules are 100% hand-tested for quality assurance and compatibility and feature high quality, gold-mirrored XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ Gold series module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
* XTC (Xtreme Thermal Convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. In this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. At the same time, mechanical stability is maintained.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.1V ± 5% without invalidating their OCZ Lifetime Warranty.
- 800MHz DDR2
- CL 5-5-5-18
- Unbuffered
- Gold XTC* Heatspreader
- OCZ Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
Price: £61.99+VAT (£74.01 inc VAT)
BUY NOW!!
OCZ 8GB (4x2GB) PC2-6400C5 800MHz Quad Channel Platinum Low Latency XTC Series DDR2 (OCZ2P8008GQ)
The PC2-6400 8GB Quad Kit is ideal for enthusiasts, professionals, and DIY system-builders using Windows® Vista™ as their choice operating system that require the performance of high-speed memory. The ultimate upgrade for hardcore gamers, the latest PC titles require large capacity memory to deliver the most powerful, stable system performance and maximize gameplay. The PC2-6400 8GB Platinum Edition is the ultimate memory solution for the latest visually-intensive PC titles, and provides unsurpassed reliability and performance to unleash every graphic possibility. The 800MHz Platinum Edition runs at exceptional 5-4-4 timings, offering tighter latencies than typical 2GB modules, and provides unprecedented bandwidth on the latest platforms. As part of OCZ’s Platinum series, the PC2-6400 8GB Quad Kits are engineered to satisfy the demands of overclockers and enthusiasts with an optimal balance of performance, overclocking strength, and capacity. The 8GB PC2-6400 Quad Kits are 100% hand-tested for quality assurance and compatibility and feature high quality, platinum-mirrored XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind. With its ultra-fast performance, high quality and reliability, the OCZ PC2-6400 Platinum 8GB Quad Kit is a perfect memory upgrade for today’s memory-hungry Intel platforms.
- 800MHz DDR2
- CL 5-4-4-18 (CAS-TRCD-TRP-TRAS)
- Platinum Mirrored XTC* Heatspreader
- 2.1-2.2 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
Price: £119.99+VAT (£140.99 inc VAT)
BUY NOW!!
I think you will agree these are some great deals on memory! :)
8 gig for £140!! Storming deal and pretty futureproof as well! Could do with a 4 gig set myself when I finally upgarde to windows Vista ultimate.
Rob H
8GB for £140! WTF!
I paid more than that for 2GB of Geil ULL at the start of the year!
i've got some money, but i havent bought my christmas presents yet :( so thats a whole lot gone... do it for january, then i'll have more money and 2nd payday so should have about £600 to play with, then bring on the 4GB ram, E2180 and P35 :cool:
Shames the 8gb ocz stuff requires over 2 volts, my motherboard doesnt do that :(
Will have to go for the 2 kits of ocz 4gb@5400 I think it was as these run at the standard 1.8volts.
Ordered the XMS2 this morning, was rude not to at that price. Could do with the extra RAM with Vista 64bit.
Should come tomorrow, but as it's Royal mail, I think sometime in mid January is realistic.
I was planning to get 2 more gig, but now. what happens if I do get 4 gig?
I have 8gb and to be honest I wouldn't recommend it at the moment. 4gb gives better performance for everything other than image and Video editing (all that kinda stuff) and even then I don't know how much I would notice it over having 4gb.
I bet games run better with 4gb as the timings are tighter and it's quicker to get the data etc.
Maybe in a years time 8gb will give an advantage, I've been uhhmming and aaahhhing about taking out 4gb and selling it. :o
32-bit will show you around 3.2Gb. Its a total of 4gb, but then you take off all the other memory in your system and then a little bit. Thats included video ram, caches and a lot more. So you get roughly 3.2gb.
I've got this sneaky feeling with memory prices at such a low price i.e DDR2 at a time when usually memory prices are sky high must mean that manufacturers must be trying to get rid of as much as possible.
This is just an hypothesis, but DDR3 will become mainstream next year whether we like it or not. . . prices are high now but you watch the next few months. :)
I also think people just aren't spending money at the moment. It's not just RAM that's being heavily discounted - the OcUK 24" monitor is very good value, their GTX is probably the cheapest in the country, but most folks are happy with £35 worth of RAM and the 19" they paid £200 for last year. Most new builds are based on 2180s or Q6600's at best and the days of £2500 PCs at Christmas are confined to a few really ignorant punters who have confused "Where in the world?" with "How on earth can they charge that?".
The only thing that's commanding a premium at the moment is the "bargain" 8800GT, and that's actually more than an 8800GTS used to be, although it's performance is very good.
Agreed - it's a slow burner - like DDR2 was.
[ img ]http://www.overclockers.co.uk/pimg/MY-108-CS_400.jpg[ / img ]
Nice one :cool: Ordered
Just to prove myself wrong....Royal Mail did their job right! XM2 RAM came today!
Excellent service and price, highly recommended A++++++ and all of that :p
