Not necessarily, firing your own BVR missile with the intention of getting the other aircraft to turn is one tactic. You can then try and continue to provide positional updates to your missile (either directly from your radar feed, or using someone elses through data links), while trying to defeat the one fired at you by the aircraft that turned away. Of course this is a crazy tactic, and why it helps to get your ordnance away firstRight, but if your opponent fired a missile, shouldn't you be trying to dodge it?![]()
