Help! Is anyone feeling kind...
21 Feb 2004
...enough to help a very distressed PS3 owner, who wants to get online, but can't get it to work!.
Would appreciate a walk through if possible, before I sling it out the window!
Can use msn if necessary.
Would be very appreciative - thanks
If trying to access via ICS, I guess you can just manually key in an IP the same range as your PC, i.e. 192.168.1.2, but set the gateway to the actual IP of you PC, in this case 192.168.1.1 - I would imagine that ICS allows your PC to act as a router of sorts :confused:
Edit: a quick Google clicky.
Scort.
