OK, moving to the USA for around 6months, by current PC is like 2/3years old built by myself after taking advice from you guys.
It has worked amazingly well all these years, and i've never had a problem with it, but it is old.
Basic spec is:
GForce 6800 GT Glacier (256MB)
Athlon 64 3500+ Winchester 90nm(Socket 939)
3GB GeIL PC3200 Value Dual Channel (2x512MB) + (1x2GB)
Onboard Sound (Dont care about sound quality)
120GB IDE HD (Maxtor I think)
Antec NeoPower PSU 480
I also have a nice Antec case which I paid like £100, but sadly that wont fit in my suitcase, so I need to know what parts I can use when I build a new PC.
I havent really looked at PC components for a long time, but I assume I can use the powersupply in the USA, it says on the manual:
'Universal input automatically accepts line voltages from 100V to 240V AC'
Does this mean I can just get a powercable in the USA and the PSU will work? Oh and the PSU has a PCI-E cable thing
So I guess im looking for a new mobo,CPU,Graphics Card and Memory. I'll pick up a case also but it wont be fancy.
I'd like a new HD, but would also like to access some data on my old drive which is just a Maxtor IDE, can you do that?
Budget wise, not sure really, I have a 19" LCD monitor which is coming with me. I guess around £250 - £500.
I would like to play games somewhat on it, not bothered about crazy FPS, but I do play Everquest 2 and would like whatever I get graphics wise to be a decent upgraded over my 6800 GT.
Thanks folks,
Basic spec is:
Thanks folks,
