Hey
I'm thinking of getting a dual shock 3 for Christmas and am just wondering what you think would look best - the black or ceramic white version? Also, in what way are the new thumb sticks more accurate?
Unless you have a white 360 controllerOne advantage of a white one is that you will know straight away its the DS3
Unless you have a white 360 controller of course
BTW, back to the other question - So does aiming feel more precise? Also is it true the triggers need more pressure?
I got a white one so I could see quickly at a glance which was the DS3 and which was the SIXAXIS.
I found on the SIXAXIS that you generally have to move the sticks about 3/4 way of their travel distance before whatever you controlled on screen responded. With the DS3, a slight nudge, like the 360's pad, is enough.
Both my sixaxis controllers don't suffer from any problems.
Maybe i am just lucky...Twice.
Josh
There's a 'deadzone' on the analog sticks that are very severe in a lot of games - Warhawk for example feels heavy when you aim mainly due to deadzone. Other games like Uncharted are very speedy and responsive. It's also to do with the speed of turning for the amount of nudge you push. The 360's sticks don't need to be nudged as much as the PS3's sticks do to reach the fastest turning point. This is not necessarilyy good or bad, just a defining characteristic, and as I said earlier, PS3 software developers can compensate. Warhawk doesn't compensate for deadzone, Uncharted does. Try the aiming on both, you will certainly feel a difference.
The fact that your Planet Earth blu-ray was buggered and you missed your DS3 delivery cancels out your good luck (twice), and now the universe is in balance again.
rp2000
Black. And order quick if you want it before xmas!! And don't pay more than £37 or you are doing something wrong.
rp2000
