Best Panel Air filter money can buy??
3 Jan 2007
Derby
So im looking at replacing my panel filter on my escort and drilling the air box after deciding against an induction kit. So whats the best panel filter i can buy?
Standard.
A regularly replaced paper filter will be better for the air/fueling system than any "performace" one will. In the context of every day cars anyway.
£5 vs. £40, I know which I'd go for. ;)
Standard.
By your same argument a regularily replaced/cleaned performance filter is better. There's a reason racing teams use performance filters, but yes if you don't clean it regularily it's pointless. Thankfully it's not a hard task and can save you ever having to buy a filter again so can actually work out cheaper in the long run.
Instead of just whacking in a "performance" panel filter, work on getting more fresh air in to your airbox.
I have a length of aluminium ducting running from my lower bumper vent up to the airbox where I'm running a standard panel filter. The air that enters the airbox is cold (low to the ground) and high pressure (because it's 'forced' up the ducting) and on a rolling road I developed 8bhp over stock with that induction coupled with an exhaust with no baffles.
The "induction kit" cost me £12 in total and somebody with a similar set up on a MK4 Golf GTI measured the airflow and it was actually greater than with a K&N Typhoon kit fitted - an induction kit worth £150.
I've got an ITG panel filter in my car, certainly makes the car rev a bit cleaner, whether it gives any power or not I doubt it!
It basically filters less than the OEM one, letting more air through and making it sound louder.
I'd rather pay £5 every 3k than £40. and I'm sure many others would agree.
Remember I said "in the context of every day cars", racing cars are completly different on my opinion.
I can't remember the figures, but i read up about performance ones vs factory ones and the amount of dirt particles they let in is considerably more. I have fitted big induction kits to a couple of my cars but only because i have already played around with them and the std air box was restrictive. Both times they were shielded and put right into the fesh air.
