There the same specs as far as i know...What's the difference between this and the n95, then?
Apart from the n95 has bigger screen
and the n82 has better camera flash...
YesOriginal N95 had less memory too.
Anyone know when this or the N95 8GB is out on T-Mobile?![]()
Can no-one host a vid for me to show the vid quality?![]()
Basically no. Certainly the increased ram has far less of an effect on speed than the faster processor. Original N95 has same amount of RAM as N73 but faster processor. It is far more responsive than the N73 even though the RAM remains unchanged.So the RAM doesn't account for any increased performance: ie speed and responsiveness when switching between menus with multiple programs open?
I think we're starting to get a tad anal here...![]()
Adding more Ram can easy make more difference then a faster processor if the phone is running very low on ram....Basically no. Certainly the increased ram has far less of an effect on speed than the faster processor. .
Eh? The N73 had 20MB total RAM with an average of 6-10MB free, the N95 has ~64MB total RAM, average of ~20MB free. Think you need to do some reading up on the specs!
SDRAM Memory: 64 MB
~14 MB Free Executable RAM Memory
My bad I mistook the "free" bit for "total", my mistake. Either way you're still being a tad pedantic... it really doesn't matter and you're making a huge kerfuffle about it. For the record my N73 averaged around 10MB or often less free memory on average, often dropping lower. I didn't reboot it daily. Considering that the phone always got more sluggish the more RAM was in use I think it's safe to say RAM does improve performance. Try using Windows with 256MB memory and a X3800+ processor. Switch to 2GB RAM with the same processor and you'll find everything runs a lot amooother and quicker.![]()
