2x HIS 3870 & ABIT IP35PRO motherboard
4 Feb 2007
hi im on a abit ip35 pro motherboard, (now i no its not crossfire enabled)
but when i run 3dmark 06 with 1 card installed i get 12600 3dmarks
now when i put in a second card in the Black x4 slot i can get 17030 3dmarks
does this mean my gfx cards are running in crossfire? even tho the motherboard does not support it.
i have 2 x HIS 3870 512 gfx cards
allso when i play COD4 there is no frame rate improvement at all with 2 cards, its even worse with 2 cards i get framerate drops in certain areas of the map when playing
even with the crysis benchmark mod there is only 1 fps difference
maybe its a ATI Driver issue ?
the reason im asking is im thinking of getting a Asus Maximus Formula SE Intel X38
im not shure *** to do
ABIT IP35PRO http://www.overclockers.co.uk/showproduct.php?prodid=MB-135-AB&groupid=701&catid=5&subcat=913
If your seeing huge boosts in your 3dMark06 scores with 2 cards it must be working, Crysis doesn't support crossfire however, so this will be why you are not seeing any differences in that. Probably will be the same with CoD4.
CoD4 runs fine for me, but NOT on the Crysis hotfix drivers, I had to run the standard 7.11's.
I get a good 100+ FPS at 1920x1200 in most places with Crossfire Enabled.
im on the crysis hotfix drivers
i run 1024 x 768 normally i just trying out 1152x864
sync every frame ON
Dual video cards Enabled
shadows NO
specular map NO
depth of feild NO
GLOW NO
Number of dynamic lights OFF
texture filtering TRILINIEAR
anistropic filtering OFF
Texture resolution NORMAL
Normal map resolution NORMAL
Specular map resolution NORMAL
my monitor is set to 100Htz + FPS is capped to 100fps
I have a question. I got a 3850/256 i am happy with it but i like to run the games at the native 1680x1050 res and playing games like GOW (loads of textures) i feel it lacks VRAM. Is it a good idea to crossfire it?
I am a P35 user too.
i just tried 7.11 and it seems worse than the crysis hotfix drivers :(
Did you install on top of the Crysis hotfix drivers or did you uninstall/ safe mode / Driver Sweep / reboot then install of 7.11's?.
i've got no problems with my 3870's in vista 64 with 7.11 cat's
the crysis drivers were for me only good for crysis and crap for everything else.
