I’ve had the covers off mine for years because they looked better that way.
Never caused me any problems.
No, I could never destroy my babiesYou're the guy who drunkenly stumbled and destroyed yourself/your hifi aren't you?
Leave the covers off OP, they'll sound a little better if you do. Just put them back on if you have kids in the room.
I have walked into them during the night though...my fault for awful room layout![]()
depends how you like the sound. you'll probably find that the covers filter out some of the harshness in the treble, for example
Not at all. Speaker covers are acoustically transparent.
Not always.
I have owned Mission 760i, Mission 751, Mission 753, Mission M70 amongst others.
I have found that when I take the grilles off, the treble is clearer/harsher. Putting the grilles on muffle the treble, ever so slightly. Bass is unaffected.
Obviously different grilles/speakers will behave differently.
PS. I'm not a Mission fanboy or anything, it just so happened that whenever I needed a pair of speakers, the Mission speakers would either be award winners or offer the right value for money, at the time.
In a blind test I was able to tell the difference between the covers being on and off my Mordaunt Short speakers. Just like I was able to tell the difference between bi-wiring and different cabling.
Personally I find it is it the only fair test and the only answer to those non believers who without experience just state "it can't make any difference"
I've tried it on a couple of systems and had to just guess, and it was really just a guess... Maybe the covers didn't make a difference on those, or my ears are crud...
