But no one will rob you for a cheap watch, so there's no pointWhat's the point? A cheap watch tells the time just as well...
you are so right, I will sell all mine , thanks for the info![]()
hell I even hear that people nowadays spend over a hundred pounds on a power supply.
£1700 seems fine ( assuming box and papers )
the base watch is worth £1100-1300 ( add £1-200 if sapphire crystal model )and then the dial which looks to be a factory one adds to it ( about £300 )as does the bezel ( this looks aftermarket so difficult to value ) , if you post the first bit of the serial number ( either X123..... or 123.... ) then I will get you the date
Model number 69174 and serial 2593.
