asus ai suite and vista 64 (sp1)?
Caporegime
18 Oct 2002
Ireland
Anyone have any probs getting this to work? I load it in and get an "ai suite has stopped responding" message. The program though stays open but nothing shows in the panels, temps, voltages etc all stay empty. :confused:
Can play around with the tabs etc but they all remain blank for some reason.
Hi, are you using the latest version on the Asus download site, did it work ok before you installed SP1?
Chris
Asus seem to spring up new versions & not populate the utils downloads section for all motherboards!!! :rolleyes:
Their FTP is a bit of a mess too so it's almost impossible to difinitivly tell which the latest version is:(
I had loads of problems with AI Suite, to the point where it doesnt work @ all :confused:
Just noticed a newer build (1.03.17), havnt had time to try it out yet...
http://dlsvr02.asus.com/pub/ASUS/misc/utils/AISuite_V10317.zip
Far as im aware its the latest version, already had sp1 installed before i got it.
Hi, why I asked about vista SP1 is that it isn't actually out yet, although it is in release candidate form. Whoever installed it might have done you no favours, it might not even be the latest...
Chris
Wel the newer build sort of work slightly better than the last version, instead of everything reading zero or being totally blank almost everythings reading zero but im getting a temp reading for the cpu and "system". And thats it. :confused:
AI Suite Sucks, it worked on my PC for about 30mins.... then died PoC:rolleyes:
but i've been using SetFSB works very well indeed :D
