Caporegime
 - 8 Jul 2003
 - In a house
If it's anything like the original GX2 it will be advertised as a 1gb card but only have 512mb of available as it's two cards splitting the total.Dont like the look of that, and esp since I read it will be a 256bit interface for 1 GB Memory.
Prob is same card and fake info.
That was said about the 7950GX2 but once the drivers had matured (like most cards) it was a killer piece of hardware.If games sees this as a single card and it's effective, it'll be greatBut i think this is basically bogus, anything but releasing a single killer effective card would be pointless.
As i mentioned above. Each core will probably use half of the 1gb not the whole amount.Why do they bother wasting 512mb of ram and putting it on when it cant be used?
I 'had' to upgrade to an 8800GTX to beat it as the 8800GTS 640mb wasn't far enough ahead to justify the upgrade cost.
I see no reason why this shouldn't be a good card. Based on how 8800GT's perform in SLi should give everyone an idea of how this could perform if done right.
gt
Each core has it's own identical set of information saved in its own set of ram - bitmap and texture details etc. 1gb in total is used but it's two identical copies (512mb each) of the same info for the game level.So both cores did use 512mb of the memory? or 256mb each? So why when you have 2x GT's or w/e do you only get 512mb memory, the other 512mb is not used![]()
My gut feeling, and wishful thinking, say we'll get an 9800GTX and this 9800GX2.Ew, this doesn't make sence, I thought the D9E was the next gen card not two G92 bolted together? Surely that is the 8850/8950 ?
Would be very nice if they have... it would pack a considerable punch if that turned out to be the case!Anyone else suspect they may have sorted out Quad SLI, seeing as triple SLI seems to run ok?
Maybe you should read better, it clearly says the picture is of a 7950GX2.what a fake guys come on its 7950gx2 read better![]()
