OCUK 8800GT 512MB temps & overclocks
Permabanned
15 Aug 2006
Gainsborough, Lincs, UK
Hi peeps, I know there on offer atm and im very delighted to say ive got one!
Ive got it running on 100% fan speed (not that loud really) and it idles at:
31C Core Temp
40C Temp
Thats overclocked at idle....
Ive managed to get it to 682 / 1507 / 908 with no errors in ati tool. however i cant psyically see any errors and its still way cool under stress, so im gonna clock it more i think even if ATI tool says there are errors, see what happens.
If people would like to post there clocks... ill make a list!
Overclocks:
mattymaxx - 682/1507/908 - idle 29C - load 51C - fan 100%
homi-sid-al - 700/1600/1000 - idle 50C - load 65C - fan 100%
Raikiri - 729/1822/1950 - idle n/a - load n/a - fan n/a
come on peopel some of u must hav bought the ocuk its *** value.
update, now running on 682/1533/932 stable! :-D
This card rocks out the box. there 600/1500/900 stock!
Not an Ocuk model but as they're all the same I may as well list my current (not max) clocks.
729mhz core
975mhz mem
1822mhz shaders
how do u get your cores so high!
Ive got mine to 682 any higher creates errors in ati-tool!
lol any advice? or is it just luck of the draw....
added to list. anyone else?
Matt.
ive got it to 720 but ive got a stupid software problem cos if i go higher than 700/1625/1000 3dmark06 stops and it says something like graphics driver stopped working or some crap like that,think its a vista prob,you should get 700 core easilly enough though i would have thought:confused:dont know if it makes a dif but i use rivatuner.
i get the 3dmark06 problem loss of driver too. what are you using for stability?
if i go much higher on the core ut3 will crash....
Matt.
u tried ut3? i might hav to try some other games see if its just ut3 thats crashing wen clocked that high...
Matt.
hmm,tbh im not sure if i am or not:(ive just fired it up and i cant see anywhere it says what version it is:rolleyes:dont remember getting any patches for it but that dont mean anything:(ill look into that.
