yep, but i seem to have some sort of problem with my water cooling setup the temps are a little high. the rad is getting very warm so i know the heat is going in to the water but rad doesnt seem to be taking the heat away and that with a pa120.3 with 120mm 5v modded deltas . i have a mate with the same set up and his temps are 12c lower than mine ilde.
Get the newest build of Speedfan ideally the last beta (final is due), it reads correct temps and it aint always 15C higher (depending on CPu model), same with Everest.
Yup , on my kit (E6600 / P35-DS3P) speedfan agrees with coretemp etc![]()
Looks very promising, 3600MHz-4000MHz must be mentally fast on a quad core!got to love these new q6600 cpus
When your finished with the early stages of your testing move onto some priming and get your results posted here:
The Intel Quadcore Database
Or a single core if the apps arent multi-threaded, but i guess you already knew this![]()
Thats becasue you havnt got a kentsfield/go chip![]()
Whats a single core?![]()
I wouldnt even consider buying single core again.
