hmmm thought 2 gb would have been more than enough tried removing sp1 still the same , will try fresh install and no sp1
Oh I wonderd when you'd show up, Fire Wizard.
Sorry to be off topic. Due to the content of your other posts in the Windows section, are you by any chance studying Microsoft or work for them?
ok i have vista x64 a q6600 lastest drivers sp1 rc1 installed , this is a fresh vista install 8800 gtx again latest drivers cant run cod4 worth a crap ! jerky as hell saw videos on u tube with a guy with same set up runs silky smooth so whats up , also have 2 gb ram thats at 1440x900 ! this card should eat it for breakfast , tested my memory etc as well , checks out , i didnt have a problem with the demo etc of cod4
Also 64Bit Vista will use more memory than 32Bit, it would be smoother with 4GB of RAM.
Im glad you sorted it out but from your first post it seems you did a fresh install & installed the beta SP1 from the get go, bad idear if that is not the case then it should have been ok before you put Beta SP1 on because thats what you have now & you should have worked out that things went bad after beta SP1 & did a re install anyway with out the moan.Update , thanks guys! fresh install of vista again x64 , and didnt apply the rc1 sp1 , woooooooooooooooowwwwwwwwww game runs like butter now all maxxed , no slow down ! cheers!
