THE BENEFIT OF MR SLI!
26 Oct 2007
Death Star or Mount Doom, it depends on the day.
Ok lads and gals, in laymans terms what are the benefits of SLI?
Where else do you see an increase other than framerates? and do you need the exact same card to do SLI?
You need a secondary card of the same type, but doesnt have to be the same brand (ie 2x 8800GT, but an Inno3d 8800GT and Gigabyte 8800GT would work fine).
The benefit of SLI is just that, frame rate, its really for people who want to use high detail levels at high resolutions (1920x1200, 2560x1600) often with AA/AF, where a single card can't cope. However, to be completely honest, Nvidia SLI implementation has never been great, often only seeing an average 20-50% performance improvement for the additional card.
Crossfire is ATi's equivalent, and judging by Marscay's recent testing and thread on this forum, seems ATI have begun to make significant improvements in dual card utilisation, with him seeing an 80-100% improvement in all the tests he tried, with a little tweaking.
So is that all it does incease frame rates on higher resolutions for if you have a big monitor! Doesnt it prove your framerates if you just play on 1280 x 1024
Have a read of www.guru3d.com or www.techreport.com which have some nice breakdowns of the ins and outs of SLI and Crossfire because it will save you time and help you gain a better understanding.
SLI will only improve where there is room for improvement. At 1280x1024, a modern CPU can keep up with the graphics card in that it can shift a game's wireframes around quickly enough to keep high minimum frame rates (i.e. stop the graphics card from spinning its wheels, as such).
Also, the texture demands at such a resolution aren't as high as at 1600x1200 or higher, therefore most mid-range graphics cards have enough pixel-shading power to do the busines.s It's only at higher resolutions where single graphics cards tend to struggle that SLI adds any notable benefit because of the added horsepower, memory, etc.
Besides, if one can get a minimum of 60fps at 1280x1024 with high IQ, what's the point in more graphics card oomph? SLI can potentially improve upon it, but there would not be any noticeable difference.
At 2560x1600, the minimum frame rate may be down at around 20fps; assuming the game is not CPU limited, adding a second card will shift that up to a maximum of 40fps, instantly making the game more playable.
And please, make sure your spelling and grammar make sense because your post is otherwise pretty difficult to decipher.
Yes, Unless you have a 24" or 30" don't bother.
I have a 24" and get on with a 8800GT, destorys everything other than crysis but well that is crysis. with SLI I could max out the AA and AF a little more or get even more frames but UT3 is the most graphical fast pased game I play and that is fine so I will save my money for the 9000s.
SLI has huge benefits if you like to play with the settings maxed... unless you play with stupidly high resolution or the rest of your PC is extremely fast you won't see as big gains with 8800 series card in SLI as you would with 7 series or even ATI's 3800 series as you will be CPU/bus limited. I like it personally because I've turned into a bit of a quality junky of late just have to have my super high res textures and decent levels of FSAA/AF.
i do disagree a bit with that. i think the performance improvment is good enough to warrant it, ONLY if you can get the cards cheap, or the second card for cheaper than the first one.
or if 9 series isn't round the corner, which will blow away slid current cards.
I must admit I'm tempted by SLI at the moment. I've seen some 8800GT's incredibly cheap (pre-order so no idea if they will ever actually have them at that price). Can't mention exact price due to the ban hammer but a pair of them could be around the same price as most people are selling single GTS's. So if they do ever materialise (doubtful lol) then suddenly SLI makes sense. I'm only considering them due to having a 30" Dell though.
