Hey Chaps,
I'm trying to hook up a Veba 7" TFT monitor to my ICE (with a car freeview tuner...) everything works except the TFT seems to be in a bad mood:
It is a Veba AV700MB - it takes 12v DC as usual, has 3 A/V RCA connections and 4 other wires, which I assumed were as follows:
black = -ve
red = 12v +ve
brown = ?? remote control?
white = ??
so i had it connected with the freeview tuner (also 12v) to a molex connector i put with the head unit 12v connection from the fuse box...
so everything should have been fine, except the TFT doesn't power up - the freeview does so the TFT should...
Funny thing is when i "wiggle" the TFT power molex connection a bit the power light does come oon.. however it's not a dodgy connection because I've tried 3 different methods to connect it (including connecting direct with the freeview's power wires)....and the power doesn't stay on at all..
Is it possible that Veba have some funny wiring colours? or that i also need to hook up either the white or brown to a 12v dc as a possible remote control turn on? this is annoying as I don't have the manual, and can't find any wiring schematics online either!!
Cheers!
black = -ve
red = 12v +ve
white = ??
Cheers!
