I do have one cut. It's on my foot when I dropped the flipping thing as the base was slippery.
The HSF only just fits in the P182.....
I have mounted it top to bottom rather than the conventional front to back as there are too many Gigabyte heatpipes etc in the way. .....
I am considering removing the fan on top of the case and making some kind of duct straight up, then using another spare 120 amber to push air. Hopefully the push pull action venting straight out will be better. So far only a 2°c to 5°c difference. Rises to 59° on all four cores in Prime within 30mins.
And yes I took the "crazy cool" plate off the bottom of the mobo so I could use the "X" brackets as this thing is heavy, as you all know.
