Best wheel cleaner?
Meguiar's Hot Rims is for fairies.:p
Meguiar's Wheel Brightner is where it's at. It last for ages and it's a concentrate so works out waaaaaaay cheaper. Just make sure you wash it all off fairly quickly as it's strong stuff.
Any good for painted wheels though?
Whatever cleaner you use, I suggest applying a coat of protection to the wheels afterwards to help prevent future build up. I only really need to use car shampoo and water now.
Agreed, some collinte wax is supposidly very good to use.
