30 Dec 2007 at 15:20 #1 matty114 matty114 Associate Joined 25 Nov 2007 Posts 1,560 Location Crewe Thread #2 FATAL ERROR: Rounding was 0.4998779297, expected less than 0.4. Ram is at 500mhz at 4-4-4-12 at 2.2v Cpu-z reports voltage at 1.368V Temps didn't go over 60*C What can make it fail?
30 Dec 2007 at 15:24 #2 Azza Azza Caporegime Joined 6 Dec 2005 Posts 37,959 Location Birmingham matty114 said: What can make it fail? Click to expand... Not enough volts and speaking to Clive.
30 Dec 2007 at 15:25 #3 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,490 Location Antrim town Loosen your timings to 5-5-5-15 and try again.
30 Dec 2007 at 15:34 #4 matty114 matty114 Associate OP Joined 25 Nov 2007 Posts 1,560 Location Crewe I set them to 5-5-5-15 doing test now. Core voltage is 1.320V now i have it set to auto in BIOS I guess i have to manually set the voltage. Last edited: 30 Dec 2007
30 Dec 2007 at 15:46 #5 easyrider easyrider Caporegime Joined 24 Dec 2005 Posts 40,150 Location Autonomy You need more Vcore thats about it.
30 Dec 2007 at 15:50 #6 matty114 matty114 Associate OP Joined 25 Nov 2007 Posts 1,560 Location Crewe It worked for 15minutes than it failed on thread 4 Rounding was 0.5, expected less than 0.4 I will go and manually set the Vcore. What do you think 1.4?
30 Dec 2007 at 15:53 #7 easyrider easyrider Caporegime Joined 24 Dec 2005 Posts 40,150 Location Autonomy Try 1.45v and keep an eye on the temps.
30 Dec 2007 at 15:55 #8 matty114 matty114 Associate OP Joined 25 Nov 2007 Posts 1,560 Location Crewe What are safe temps anyway? I'm using the Freezer 7 pro.
30 Dec 2007 at 16:01 #9 easyrider easyrider Caporegime Joined 24 Dec 2005 Posts 40,150 Location Autonomy matty114 said: What are safe temps anyway? I'm using the Freezer 7 pro. Click to expand... Ideally 60c ish Below 65c 24/7 full orthos load.
30 Dec 2007 at 16:06 #10 matty114 matty114 Associate OP Joined 25 Nov 2007 Posts 1,560 Location Crewe I set it to 1.45 in BIOS but its only showing 1.408V in CPU-Z is that right? Now its 1.352 underload. after 3 minutes the cores are 62*C 62*C 59*C 59*C and PC Pribe 2 is reporting the cpu is 66*C Last edited: 30 Dec 2007
30 Dec 2007 at 17:01 #11 ITR ITR Associate Joined 16 Apr 2006 Posts 140 Location Tamworth Hi mate, set the voltage damper to enable in the bios if you've not done so... works wonders for vdroop
30 Dec 2007 at 17:14 #12 matty114 matty114 Associate OP Joined 25 Nov 2007 Posts 1,560 Location Crewe ITR said: Hi mate, set the voltage damper to enable in the bios if you've not done so... works wonders for vdroop Click to expand... Just enabled it but it's still 1.376v and not 1.4 or is this correct?
30 Dec 2007 at 17:20 #13 young young Associate Joined 28 Oct 2007 Posts 190 Location Newcastle yeah thats normal
