To be fair with a decent PC you want a decent monitor. To say you need a decent TV for a console isn't fair to add into the comparison. On top of a £400+ base computer you're looking at another £250+ for a decent 24" LCD. Then there's all the other crap like keyboards and mice which some people like to spend another £50 odd on (why?!). It can also up upwards of £50 for an operating system. That's a good £350 without the PC.
You could nearly, some of the guys in the " Spec Me " threads surprise me (as you said tower only).
@ deadkomodo, HE NEVER said build a PC 3 years ago for £300, he meant TODAY.
Yeah and he also said it will last 3 years. Read bud read![]()
I then made the point you could not build a PC 3 years ago to last till now for £300 so what makes you think one build right now with be running PC games (which progressively seem to be less and less optimized for low end machines) in 2011![]()
And you need get your replys STRAIGHT not TWIST the posts you are trying to argue about.
Want to save cash in short term, buy a Console, play at low res on a SD TV and eventually cost more in long run after buying dozens of games than a semi decent RIG that could be built here for little over £300, then obv you need buy a Monitor but you did state "Tower only"![]()
Your the one who cant read, he still did not say, that he could build a PC to beat a 360 3 years ago for £300, it lasting 3 years is a different story.![]()
*Disclaimer I am both PC gamer/Console gamer but do love fanboi baiting
Nah he said it would last 3 years. The only way to prove otherwise is to look at the facts i.e. PC history... are you new to PC's?
Also that spec is a joke tbh... 256mb GPU ramTodays games are going to love that especially future ones
That spec is looking at medium low settings on new games TODAY
Disclaimer?. Hmmmm OK then.
Fanboi baiting you say?. If that was the case you would say something smart and leave instead of getting caught up in it.
I don't care if a console is cheaper. There is no comparison. To say you are a PC gamer but would happily play on consoles just speaks volumes about how much IQ means to you. Well in that case you have to take a step back and think that just because you enjoy the lacklustre attempts of the Xbox360 compared to your PC. Enjoy your gaming in 2008.
Correct he said last 3 years, YOU claimed he said he could build a PC 3 years ago for £300 which is false, he did not say that.
