Spec me a PS3 and Sky HD to optical splitter ?
5 Mar 2004
Leeds W.Yorks
Apparently with some of these splitters the PS3 to amp audio quality is awful, can anybody recommend one that works well ? The Sky HD and PS3 will be on at seperate times.
I got one for my xbox & Sky+ box from TVcables.co.uk, sound quality is no different than a straight cable...
Which one did you get ? the one at TV cables is the other way round, i.e 1 source to two amps. I want two sources to 1 amp.
it was one that you twisted
I cannot remember which it was but it let's you put two devices into one amp, iirc it was around 20 notes, writing this on a crackberry, so will have a look tomorrow for you!!
Optical splitters work both ways, just don't have both sources on at the same time or you get no sound at all, unless you have a manually switching one.
