multi meter should answer your question, i dont have access to one atm. i would expect the voltage to be arround 1.8-2.2v with a current limiting resistor tuned for ~20ma at whatever voltage. - this is about the range for red - green led'd off the top of my head. blue/whiles need 3.5v for full brightness but should show some light output. then again, cases with blue led's work on all mobos also. so it could jsut be a 5V output and expect a suitable resistor on the led.again, only way to know is with a DMM or a look for the technical specs for the mobo
