[email protected] (410x9)
GW8800GT @ 680/990 (169.21)
2gb 6400 (1:1)
3dmark06 score = 10800.
is this a bit low ?
Thx
2gb 6400 (1:1)
is this a bit low ?
Thx
is it all set to performance in your nvidia control panel?
2gb 6400 (1:1)
is this a bit low ?
Thx
OK, dling 169.09 beta atm, will try them now.
is there much dif between XP and Vista in 3dm06 ?
Thx
.i was averaging 500-700 points differance between xp and vista.OK, dling 169.09 beta atm, will try them now.
Thx
Grr
just tryed 169.09 beta and got exactly same result.
is there a app to check if my chipset drvs are up 2 date ?
Thx
Can you post a shot of CPU-Z showing the mainboard tab?
