Evening all,
I have a little issue with an electronics problem I'm having trouble with.
I have to design a simple circuit to give a gain of 10 with a minimum bandwidth of 180 kHz using the 741 Op Amp.
Using either inverted or non-inverted circuits, the bandwidth will only be 100 kHz (according to the bode diagram for the 741 op amp).
Would it be possible to simply connect for example, two inverting op amps together in a row, say, one with a gain of 5 and then a gain of 2? How would this affect the bandwidth?
Thank you for any help, as I'm puzzled on this.
