Not sure why you said the 8600GT is a waste of DirectX 10 hardware when the 3850 is DirectX 10 too
because the 8600 is too slow to make it worth running games in DX10 over DX9.
whilst the 3850 is just a better card anyway, regardless of what DX
Hi Josh
Actually, you can't max it out on a 9550at least not with AA turned on (or edge smoothing as Sims 2 calls it).
hi mate.
think you'll find I can, although the camera movement can be a little clunky, but it's smooth otherwise.
Last time I played it (which was with an XP2400, 512MB RAM and a Radeon 9600) it wasnt particularly smooth.
well i had an xp2600, although i doubt that would make much difference.
and was yours a 128mb 9600 or a 256mb version?
either way i wouldnt recomend a 9 series radeon to the OP there dead tech lol.
please remember people he is talking about sims 2 not the first sims, sims 2 still runs a bit jerky on a 1950xt on full settings, i know this as my last system was a 4400am2, 2gb pc3200 and xt1950xtx which my sister used for the sims 2.
got for the ATI 3000 series card over the nvidia any day![]()
