Caporegime
- 13 May 2003
- Warwickshire
Does anyone know what £150 will get you in terms of the next gen cards though? Not much I'm guessing.
Netburst was very efficient when people programmed for it rather than for windows (i.e. making good use of SSE), but you should be able to support what is present as well as what the future holds. Making a smooth transition is a much better way to introduce new technology than to force it upon people.
Edit: Chances are £150 would buy you two 9600 GT cards (assuming they are introduced at about £75 which is quite a likely offer for a -600 series card)
While that's a possibility the chances of that are extremely slim. That sounds more like the price range of the rumoured 8800 GS (y'know, the one with the funky 192-bit bus?). They'd be dooming that product to fail as they'd be launching it against a card that is not only stronger than it, but also a bit cheaper (come on, a card with 64 shader procs vs. a fully fledged RV670 core? Not gonna be a pretty one for the green team), and who the hell is gonna buy one if they can buy a card that's about 1.7x its speed for £30 more?* I'll tell you who: Nobody!
Edit: *or for that matter, spend £20 less and get a card about 1.3x its speed.
