- 13 Jan 2004
- South East
Hello,
I am hopefully off to Cornwall in a month or two and I know that you can get some fantastic landscape shots down there. I would be using my Sigma 17-70mm as it is the widest lens I have.
What filters would you suggest I pick up to help me with landscape work (could you possibly suggest specific brands and actual filters please
I expect a CP and an ND grad filter would be good. But I have no idea which ones would be good for me. I think the thread size is 72mm
Thanks in advance.
Oh, also, I do have a tripod in case anyone recommends I get one
One more thing, I know an ND grad reduces the amount of light into the lens, meaning you can have longer shutter times. But what is the actual benefit of this? Do you get more detail or something? Is it suggested to get one that is a gradient so that you can only cover the sky with it? Is that the main benefit?
Should i get a hard or soft one? So many questions
Sorry, I keep editing in more questions. For landscape photography is bracketing a good idea? Do I need to take 3 exposures even if I shoot in RAW format. Is it easy to save 3 different exposures of an image and then combine them? Does this make it an HDR image or can you do this to get a perfect exposure all over and NOT make it HDR (I don't want to do HDR images, but might try at some point)
)I expect a CP and an ND grad filter would be good. But I have no idea which ones would be good for me. I think the thread size is 72mm
Thanks in advance.
(Fantastic work as usual)
