L1Js rust stuff?? what is it?
13 Jan 2004
Leicestershire
as title really... i had a search through his HUGE thread about the golf and couldnt find a mention of a name but i'm after some of the stuff that basically eats rust and i know you used it on the golf.
anyone? :)
Not sure if it's the same stuff but i've heard good things about Deox-Gel.
" Deox-Gel is a viscous, highly thixotropic, rust remover, designed for corrosion removal on surfaces or objects too large to submerge in a bath of Deox-C. Along with the viscosity builders and preservatives, the active agents in Deox-Gel are harmless, non-toxic and biodegradable. "
that's the stuff!!!! was looking in the wrong golf thread!!!
http://forums.overclockers.co.uk/showpost.php?p=10558383&postcount=70
ta!
I use Bilt Hamber Deox-Gel, followed by Bilt Hamber Hydrate80 (the purple stuff) as a barrier/stabiliser coat.
see above - the missus beat you to it. you have Lostkat well trained. ;)
edit - almost well trained... she failed to indentify the deox-gel. 6/10.
The powder is brilliant (Deox-C) for bolts etc - there is a guy on SXOC using it on his S14a rebuild and it's working wonders.
http://www.sxoc.com/vbb/showthread.php?t=283826
thanks for that guys.
quick note, does it have to be a metal tub? or can you get away with plastic? also is it hazardous to skin or anything?
