imo:
- Flak Cannon fires too slow maybe, seems all right to me
- Scorpion primary fire damages the manta too easily manta outruns scorpion easily, balance is fine and it's quite easy to avoid if you know it's there
- The map "biohazard" needs making bigger imo, too small and it leads to being smashed apart by impact hammers constantly no comment, except I like the impact hammer
- Goliath needs to be strengthened, its far to weak and can be easily taken down goliath is already strong enough... yesterday I spawned directly into the goliath's line of fire 4 times and in a row and died every time. There's already very little you can do if it's in a good location.
- Skitching on hoverboard with fast vehicles needs to be improved, you either fall straight off or loose health from bashing into things you know you have to steer yourself too? It is too easy to fall off of a fury when there are two people but otherwise fine. The main problem is with drivers who don't drive carefully enough and slam you into the ground
- Improved loading times between matches yep
