Upgrade water-cooling now worse performance. Went from two single XSPC R120s’s to a Black Ice 240 GTS and idle temperatures are down a few degrees but load temperatures are up about 5C and still going.
I have added a Swiftech MCW60-R in to the loop as well but didn’t expect it to raise the temps that much if anything. Is that to be expected?
Both rad types are in the same place in the case, both working with fans pulling through the rad and the same fans. Do these radiators perform better with different fan types? Obviously a high fan flow will always be better but some rads aren’t as fussy as others.
Ideas will be a help please as mother board alarm will be going off soon.
