Hi,
I'm looking to get a double bed from Ikea. I have found a black-brown "Malm" frame which looks like it will do the job and will get a couple of black-brown Malm side-tables to go with it.
Only problem i have is which slatted base to get. I know i have to purchase a slatted base with the frame as it doesn't come with one and the site informs me i will need one. The reason i am confused is to do with the sizes, at first i was going to just get this one:
This one (make sure you change the drop-down on the right of the image to 140x200cm) as it is the correct width and height for the double bed i am looking to buy (140x200cm).
But i see there are plenty others, like:
This one (make sure you change the drop-down to 70x200cm), as it is half the width and i should maybe get two of them?!
The site also confused me when it says:
I was going to get it delivered to my home as none of the stuff im ordering will fit in my hatchback, so assume this HAMAR midbeam in its seperate package will be coming my way also...?
Basically, i know quite a few people shop in Ikea round these parts and remember seeing threads with the same bed in...so im hoping somebody with the bed (or similar from Ikea) will know which stooopid slats im supposed to buy...
Apologies for the thread, but thanks to anyone who can help.
HAMAR midbeam keeps your mattress in place and secures the cross-braces. It is included in the price, but is packaged separately.
Mid beam and double bed slats were seperate for me.
