When you vehicle window gets steamy
Hi all,
What do you do when your vehicle window starts getting steamy?
I normally direct HOT air onto it and open the windows slightly.
Just talking to a mate who said you should use only cold air directed on windows and to keep all windows shut?
What way is best?
Hi all,
What way is best?
, so just whack the blower on max and drop the windows a little. Rarely leave it outside long enough to get misted up though, so a bit of a non issue.
If that fails then use A/C then if that fails use the old fashioned way off the engine heat.
