Suggested filters for landscape photography
Where do you get yours from - i know some recently droped theres and it was custom made.
Are you thinking of King4aDay who droppd his B&W 10 stop? My 0.5, 3, 6 and 12 stop ND filters are all custom made. I can't really use them properly though without geting a lens hood for my Lee filter kit as I get some serious flare.
i would get a hi-tech/formatt 100x150mm ND grad set, 100x100mm plain ND set and any decent brand circular polariser, wouldnt get a holder for the grads as you can hand hold them or use blu tack
dont bother with any Cokin P sets, they are too small for ultra wide angle and cause a slight cast
what kind of casts do they throw. im using a 17mm lens atthem moment but want to get my hands on a 10mm do other filter kits would work with a polariser and filter as i may want to use grads with it as well.
yeah that was the guy. are they custom by lee filters? or commisioned by some one in the trade.
the casts are something to do with them not being totally neutral, search on the net, it will have better info than i can explain
but i found the size more limiting overall so ive bought the 100x150 hitech/formatt kit which is supposed to be very good, havent had a proper chance to try it out yet though
Commisioned by some one in the trade. Id rather not say who im afraid, as he made them as a one off and I doubt he wants to start taking orders.
Grrrrrrrrr!
I dropped the replacement in a rockpool yesterday:rolleyes:
All fine though :)
Lol. You need them attached to a piece of string, threaded trough your jacket, like kids mittens are.:p
If you're comtemplating filters you are potentially buying into a system that could end up costing you a lot of money. My gut feeling is that if you're going to go for top end filters you may want to think about upgrading your lens as well :) (sorry I don't know how well the 17-70 performs at the wide end)
Neutral Density filters are listed according to how many stops of light they prevent from passing through the lens. e.g. a filter listed with a density of 0.3 will equate to 1 f-stop, 0.6 is 2 f-stops, 0.9 is 3 stops, 3.0 is 10 stops etc. etc.
If you're down at the beach shooting a sunrise or sunset with a bright sky I'd recommend a 0.6 or 0.9 hard ND grad combined with a decent CPL
For general landscapes if you're looking to control the exposure of the sky a good starting point would be a 0.6 hard ND grad or a 0.6 soft ND grad, again combined with a CPL
If you're looking to smooth water movement or capture cloud movement it's really up to you, but you could go for a ND filter wich is rated at anything from 6-10 stops, and combine this with a CPL
And, surprisingly no-one seems to have mentioned an IR filter :)
This can add an extra dimension to landscape photography, go for the Hoya R72
I`ve never really liked IR filter shots , not sure why though . maybe i dont see what benefit they give to a photo, unlike CPL`s and Grads which can aid in getting perfect exposure and colours
im still waiting for my free 350d to arrive. that i will be converting to a fast infrared camera.
Thanks dude. The 17-70 is alright wide open, a little distortion. I only can compare it to the kit lens I had (now sold for £25 or something, lol) and it is much better than that. I can't afford a wide angle lens at this time.
Am I right in thinking a CPL will just screw on the front of the ND filter? If so, do I screw on the ND filter or the CPL first?
One more final question. Does anyone know of any filter packs, that might include all of the above in one? Or do I have to buy all of them seperately?
Thanks
Wow, that is absolutely incredible. Could you email me a high res version that would be happily blown up to A3?
Well. I got a Sigma 10-20 in the end, and I have a 77mm CPL and a 10 stop ND filter now which just arrived. I can't believe how black it is, I can't even see through it.
Looking forward to seeing what kind of effects I get though. During an overcast day, say midday, how long can I expect exposures to be? I don't want to be waiting around for 10 mins at a time really. I am wondering whether maybe I should have got a different ND now.
